Wahoo element bolt wheel circumference
bubasmario5
Postby bubasmario5 » Wed Nov 22, 2023 10:21 pm
Hello team, I have a problem with speed and distance, I hope someone will help me with this, namely in the beginning everything worked, sometimes it was lost for a few seconds and then came back, I use the wahoo element bolt device to which my ELITE SUITO-T is connected, I typed in ELEMENT wheel size application that I found on the forum, but the dimensions are not good, it goes up to 39 km/h and then stops, it does not show any more, so if anyone knows how to fix it, I would be grateful. Thank you.
Re: Wahoo element bolt wheel circumference
Postby Elite Admin S » Thu Nov 23, 2023 8:36 am
If the circumference setting is ok, you should have correct speed.
Here's a document to check the configuration, just to be sure:
https://elitesrl.zendesk.com/hc/en-us/a ... arty-apps-
If you use my e-training instead of the your cyclecomputer, does all work properly?
bubasmario5
Postby bubasmario5 » Thu Nov 23, 2023 9:27 pm
Hello, thank you for the answer, I entered the dimensions in the wahoo ELEMENT application as stated, I also tried my training application, everything works as it should, even on the bolt, the speed does not block, I hope I solved the problem and it will not happen again, I think I made a mistake in the configuration sensor on your app so it looks like that was the problem. Thank you very much.
