2 questions.
How do I stabilize the rear footings of the unit so the springs lock out. The Front ones I replace the springs with the cylinder items that where sent, but not sure of the back ones.
2. It says its bluetooth compatabile, but the bluetooth is not syncing? How do I get it to sync with the unit
RealAxiom B+
Re: RealAxiom B+
The rear foot must remain springy, so to me all seems correct.
About bluetooth, I confirm you that the trainer is bluetooth smart. But you must use a software which supports the bluetooth smart connection (not Real) and a device that supports this communication
