Issue with direto xr and ant+devices
klanyboyd
Postby klanyboyd » Thu Apr 13, 2023 7:54 pm
Hi to all. After update firmware on my traner i've lost permanently connection with my heart rate monitor wich connects via ant+ to pc through this trainer.
Somebody have this problem? And how you solved this problem?
stefan_l_01
Re: Issue with direto xr and ant+devices
Postby stefan_l_01 » Thu Apr 13, 2023 9:31 pm
The direto XR has a heart rate monitor? That would be new to me...
Your heart belt sensor transmits to your pc, or to the ant+ dongle, directly.
If it gets lost, maybe ant+ dongle gets lost (some usb ports are not stable, try another one), or maybe battery in heart belt gets low?
Postby Elite Admin S » Mon Apr 17, 2023 9:43 am
First of all, check the belt battery just to be sure.
Do also again the configuration of the HR belt.
If the problem persists, contact our support:
