I recently had a problem with my Suito T smart trainer. To be exact, its resistance can’t be controlled. When I change the resistance or Watt output in MyETraining app it only changes the value I see on the screen but not the real output. To test this problem I built a training with 3 blocks in it which had resistances of 100W, 200W and 500W. While training the value seen on a screen changed with every block but the power I was pedalling was constant.
Please help me solve this problem out, I would be very grateful.
Suito T - not changing resistance
Re: Suito T - not changing resistance
don't use smartphone app...
to check if is' an hardware problem try to control with a compatible bike computer, like garmin edge or similar, or by pc
Here's some instructions on how to check the motor behavior:
https://elitesrl.zendesk.com/hc/en-us/a ... e-Trainers
If the problem is confirmed, contact our support
Users browsing this forum: No registered users and 42 guests
