mye training
marcelo5rodas
mye training
Boa tarde, gente eu criei alguns treinos no mye training para avaliações fsicas , e o protocolo de incremento muda, porem o smartrainer não muda os watts, outra coisa , o a analizador de pedaling sumiu do software, se alguem puder me ajudar
Re: mye training
Are you sure to have configured the correct trainer?
Pedal analysis appears only with the trainers that have the power sensor inside, so if you select a different trainer the option disappear (and if you select a non interactive trainer, power also won't change).
Check again the configuration
