FTP statistics does not show in history
loebbert.sebastian
Postby loebbert.sebastian » Sun Feb 12, 2023 7:49 pm
Good evening
I have done the ftp test and the ftp value is correctly set in the configuration.
Unfortunately, when I now do a training and then open the completed training in the history, the ftp statistics is not shown, as you can see in the screenshot.
In the data summary section, the ftp correctly displayed (see other screenshot).
I run e-training 3.19.2 on an iPad.
What can I do to fix this?
Thanks,
Sebastian
Screenshot showing the missing ftp statistics
Ftp correctly displayed in the data summary section
Re: FTP statistics does not show in history
Postby Elite Admin S » Mon Feb 13, 2023 8:25 am
If you use a different device, does the graph appear?
If it is so, uninstall the software and install it again.
If the graph doesn't appear also on the other device, contact the support:
loebbert.sebastian
Postby loebbert.sebastian » Fri Mar 03, 2023 9:32 am
Just tried it with another device (iPhone), same issue, will raise a ticket as suggested.
Regards,
Sebastian
clueaxel
Postby clueaxel » Tue Sep 26, 2023 3:41 am
loebbert.sebastian wrote:Hi
Just tried it with another device (iPhone), same issue, will raise a ticket as suggested mario games
Regards,
Sebastian
That's right, I also changed the device but the above chart still appears
