Hi how do I factory reset it.
I have no idea if the P values are standard.
When i try to input them - i get no confirmation that they have entered correctly.
Problem is the stepping between climbing gradients.
From going to a zero % to a 3 or 4 % climb is not natural and like trying to climb mount everest.
What are the standard values
P1 p2 p3.
Factory reset elite rampa
Re: Factory reset elite rampa
Rampa are calibrated one by one.
Contact the customer care at real@elite-it.com specifying the serial number and the guys there will tell you the default values of your trainer.
