i am new to Direto XR and when im using Zwift the resistance doesnt change. I did a check in the E-training app and then i feel it but not when riding alpe du zwift. Why is my computer (ant+) not corresponding to my biketrainer? I use an ant+ with windows 10 and tried about everything.
No resistance when zwifting uphill
steve.hammatt
Re: No resistance when zwifting uphill
Have you paired the Controllable device (FE-C)?
Another thing to check is if the Trainer Difficulty setting in Zwift is set to zero. That would effectively set the resistance to level mode and you wouldn't feel any changes in gradient.
