direto x hardest ressistance
delancker.jan
Postby delancker.jan » Tue Dec 06, 2022 8:31 pm
my rollers are stuck in hardest ressistance since the last 2 weeks. impossible to turn the pedals twice around. Anyone knows the problem? Same problem on rouvy, zwift and my e-trainning.
it s a direto x system of two years and month old :x .
When you plugg the power in the trainer makes a buzzing sound like normal and the lights are corectly coloured. but then
When I hitt the pedals ithe tainer the sound... krak krak krak and sooooo hard I can turn the pedals a half tour and then my whole weight on the other one...
Please help me, I want to train during the winter...
cperrier
Re: direto x hardest ressistance
Postby cperrier » Sat Dec 10, 2022 10:06 am
same problem ... did you find ?
Postby Elite Admin S » Mon Dec 12, 2022 8:39 am
The problem may be caused by a problem on the electronic circuit board or the motor.
In both cases, it's necessary to contact the customer care:
Remember to specify the trainer serial number
mcurtin
Re: direto XR Same issue!
Postby mcurtin » Fri Dec 01, 2023 11:48 pm
My XR is “stuck” at a very high resistance setting and nothing I use to control it changes the resistance- Zwift, Garmin Edge 540, Garmin 955, My E Training… Upgraded to firmware 80, again no change. Opened ticket with Elite but they haven’t gotten back to me yet.
This forum is a little odd in that almost no one that reports a problem ever posts their solution to the problem.
Any ideas?
roy.nield27
Postby roy.nield27 » Sun Dec 03, 2023 12:01 am
Take the small cover off the left hand side. When you power it on does the motor rotate the screw and move the magnet tray at all? Is there a noise? Use MyETraining to change the resistance level between 1 and 16. Does the magnet tray move?
mcurtin
Postby mcurtin » Mon Dec 04, 2023 11:54 pm
roy.nield27 wrote:Take the small cover off the left hand side. When you power it on does the motor rotate the screw and move the magnet tray at all? Is there a noise? Use MyETraining to change the resistance level between 1 and 16. Does the magnet tray move?
No, the magnet tray did not move when changing the resistance level from 1-16. I did find a video on YouTube where the person had a similar issue- he cleaned the screw/thread thoroughly and applied new bike grease to the thread. I did the same and now the trainer is working as it should- both in ERG and free ride modes.
jokuha@icloud.com
Postby jokuha@icloud.com » Sat Dec 09, 2023 8:49 pm
Would you mind posting a link to the video?
Users browsing this forum: Bing [Bot] and 9 guests
