I own an Elite drivo since august 2017.
I use it mainly with Zwift, about 3 times a week.
The trainer now makes some strange noise like it would need some grease inside. It's weard.
At the begining I was just earing lightly the Divo when it was adjusting resistance upon the slope. Now it's not light anymore. I don't only hear my bike's chain.
Any known issues ?
Noisy Drivo
Re: Noisy Drivo
Please contact the customer care at real@elite-it.com adding a short video or record of the noise
nelson.bretts
Re: Noisy Drivo
Did you get it sorted I have noticed mine noisy only when unit is slowing down?
Re: Noisy Drivo
Support suggested I add grease to my noisy drivo and sent me a video for application. The did not specify the type of grease to use. It is a white paste in a "wladoil" branded can that says "dynamic fluid" at the top and "greases" below. I've asked for clarification, but maybe someone on this board will respond faster than email support.
I am thinking it is the GREASE HS 100 on this page, http://wladoil.com/portfolio-item/grass ... reasehs100, but hoping for some confirmation before adding grease to my drivo.
franklin.yawn
Re: Noisy Drivo
Any response on this from Elite? My unit started making "dragging noise" when I stop pedaling and let the fly wheel go to full stop.
Re: Noisy Drivo
@franklin.yawn
when there's strange noises or sounds, the best solution is always to contact the customer care at real@elite-it.com adding a short video with the noise. If the video is too large, upload it on a file sharing site (like wetransfer or sendspace)
pasqualemangiola
Re: Noisy Drivo
same problem
i also noted a belt skidding in out saddle position when
60 rpm
380-450w power
7-15% steepnes simulation by zwift
36-23 , 36-28 gear
link of the video
https://youtu.be/FpKmxhOnTyo
60 rpm
380-450w power
36-23 , 36-28 gear
link of the video
