Hello everyone,
my issue in a few words ...
the resistance while using zwift is extremely high (on flat routes) and this happened from one day to the next. On a flat route
in the easiest gear, it feels like stepping up a mountain (very high resistance!). Changing into a higher gear makes it even more difficult. So I guess that I have to lower the base?
Updating the firmware didn't fix the problem either.
Any ideas what it could be and how I can fix this problem?
Thanks for any support ...
Best,
Martin
Resistance Zwift - Suito 2020
eric.wuyts4
Re: Resistance Zwift - Suito 2020
I encounter the same problem with Suito T which is one year in use….
Did a trainingtest via Elite app -> changing the level of resistance has no effect on the trainer.
Tried to calibrate -> no result
Updated the software -> no effect
Very disappointed in the Elite Suito T…..
Kr
Eric
Kr
Eric
m.narovnigg wrote:Hello everyone,
Best,
Martin
try to calibrate
if fail ask for Elite assistance
