Power readings, don't make sense with new Android Tablet
bobpjones
Postby bobpjones » Wed Sep 14, 2022 2:35 pm
I have recently changed my old Samsung Galaxy tablet for a new one.
The old one was a Galaxy Note 10.1, Android version 5.1.1
The new Galaxy Tab 8, Android version 11
Having installed the App on the new tablet, I find that the power readings don't make sense.
It's display a six-digit number, which also screws up the calorie count, and likewise training stress score.
Any ideas as to cause, and solution?
elite training screenshot.jpg (176.5 KiB) Viewed 10383 times
Re: Power readings, don't make sense with new Android Tablet
Postby Elite Admin S » Thu Sep 15, 2022 9:05 am
Wow. that's really weird. First time I see something like that.
Which trainer model do you have?
bobpjones
Postby bobpjones » Thu Sep 15, 2022 12:12 pm
Muin B+
Postby Elite Admin S » Thu Sep 15, 2022 12:21 pm
Are you sure to have set the proper number of flashes?
If it is so, contact the support as there may be a problem with the misuro:
bobpjones
Postby bobpjones » Thu Sep 15, 2022 8:47 pm
Flashes? What are they?
Postby Elite Admin S » Fri Sep 16, 2022 11:40 am
In the misuro, when you press the little button on the side of the battery holder, the red led does a certain number of blinks.
This number indicates which trainer is being used with misuro.
Pressing the button again, you'll increase the number of those blinks.
You have to check to have selected the correct number as indicated in the misuro installation sheet
https://drive.google.com/file/d/0B_4_od ... D1CGu4XmdQ
bobpjones
Postby bobpjones » Sat Sep 17, 2022 2:58 pm
Correct settings. I at the moment I'm still using my old tablet, which gives the correct values, but the new one doesn't. I'll raise a ticket.
