Re: my Direto XR
I've noticed that, generally when changing gear, the power readout can jump quite significantly one way or another for a few seconds. Is this normal?
Also, how accurate is the cadence readout given it's determined from power data which is fluctuating?
Thanks!
Power fluctuations when changing gear / cadence accuracy
Re: Power fluctuations when changing gear / cadence accuracy
During a gear changing, it may happen to have fluctuations and wrong cadence.
It depends on the fact that you "interrupt" the power transmission for a moment. It shouldn't last much, though.
Also, it depends on the gear itself and how much fluid is the change.
