I have attached 2 pictures. One picture is of a rubber seal and and spacer that belongs on the hub but have come off.
The other picture is of the hub with the rubber seal and the spacer circled to indicate where they belong on the hub.
I was changing my cassette to install and new one. When I removed the cassette these pieces came off. I cannot get them back on the hub because the rubber seal (o-ring) has stretched.
My trainer is still under warranty and I would like a replacement hub. I emailed info@elite-it.com and they thought the issue was me not knowing that I need to install 2 spacers because I am using a 9 speed cassette.
I am hoping someone from support reads this and can help me - i.e. provide a replacement o-ring or provide the dimensions of the o-ring so I can replace the o-ring.
Thank you,
Mark
Direto XR hub problem
- IMG_8977.jpg (202.25 KiB) Viewed 4760 times
- 1014233_CORPETTO_CAMPAGNOLO_PER_RULLO_VOLANO_E_TURBO_ROTEO.jpeg (144.83 KiB) Viewed 4760 times
Re: Direto XR hub problem
Is the o-ring broken? In the photo it seems ok...
If it is so, you can place them again in their place
Thank you for the reply. The o- ring is not broken. It is stretched such that it does not fit properly on the hub. Additionally the metal spacer beside the o -ring in the picture came off. My apologies, the picture of the hub is a stock picture.
I wanted to show what the hub should look like.
