Bike Compatibility with
Wilson0503
My wife has an ELITE QUBO fluid trainer, which she was given as a gift by a close friend for use with her previous hybrid bike. When we were married, I gave her a Trek Domane SL5 Disc WSD road bike, which has a thru axle (believe 12-mm). I know that I will need a skewer for the Trek so it is compatible with the QUBO trainer. What type of skewer do I need to purchase so she can safely put her bike on the QUBO trainer? I think the trainer came with a skewer (TranzX on the quick release handle) but I have not removed the bike's thru axle yet to see if the TranzZ skewer works (or not). A table from the ELITE website refers to an "ADAPTER 1020008". Is anyone able to shed light on this dilemma? Or should I contact Trek? Thank you!
Re: Bike Compatibility with
Please check in this document if your bike is compatible:
https://elitesrl.zendesk.com/hc/en-us/a ... patibility
If it is compatible, you'll have to purchase this adapter:
https://www.shopelite-it.com/en/sensors ... -thru-axle
Wilson0503
Thank you very much for your helpful reply. I believe that the thru axle adapter will work with my wife's bike, and I have ordered one for it. Keeping my fingers crossed! Cheers!
