Pedaling analysis while zwifting
pierre.lepeer
Postby pierre.lepeer » Sat May 07, 2022 9:16 am
Is it a way to use Pedaling analysis while zwifting, without interferences between the 2 softwares ?
My setup:
    Direto XR-T + Elite Cadence Sensor
    Bluetooth cadence sensor
    Zwift on Apple TV + Companion
    MyElite on MacBook Pro with ANT+ USB key
    Polar H10 Dual Bluetooth + ANT+
Is the Direto XR-T able to send informations via Bluetooth and ANT+ at the same time ?
Is it possible to disable the power control in Pedaling analysis ?
When i only connect my Direto to my MacBook Pro via ANT+, petaling analysis works.
If then I connect Zwift via BLE/Companion, Pedaling analysis stops working on the MacBook.
Re: Pedaling analysis while zwifting
Postby Elite Admin S » Mon May 09, 2022 8:11 am
I'm sorry, pedal analysis is not meant to be used while you do other trainings.
pierre.lepeer
Postby pierre.lepeer » Wed Jul 13, 2022 8:51 am
Isn't it possible
to to set up My eTraining in order to use Pedaling analysis without control of power, via ANT+ on Mac
and Zwift via Bluetooth on AppleTV ?
It would be nice to see Pedaling Analysis while working out !
pierre.lepeer
Postby pierre.lepeer » Fri Dec 09, 2022 11:42 am
Today I tried :
Zwift on my Mac via ANT+ dongle
Pedaling analysis via Bluetooth on my iPhone[/list]
And it worked !
Users browsing this forum: No registered users and 45 guests
