Software interface specification needed
Where can we get the software interface specification for using Elite direto XR-T in an App?
Re: Software interface specification needed
You can find the minimum requirements on our website.
Here's for you:
iOS: IOS 12.0 and up
Android: Android 4.0 and up
Windows: Windows 10 and up (min Intel Core i3 - 2GHz processor, 2GB RAM, 7200 rpm disk or SSD, 8MB video card)
MacOS: MacOS 10.12.0 and up
Here's for you:
Thanks, but this is not what I mean.
The specification for writing an App is needed.
Do you mean that you're trying to write an app and connect to the trainer?
Our trainers use the standard ANT+ and BLE protocols, which are public. You can find them on the net.
Yes that's what i meant. Thanks for the info!
ipsummedicare
- Contact:
Elite Admin S wrote:Hi
Here's for you:
Regards and thanks
Best Diagnostic Centre in Lucknow
