Hi all, I have an issue with a small fluid leak on my turbo Roteo, which is several years old and likely out of warranty.
Is it possible to obtain a new o-ring seal and oil? If not, is it possible to find out what type of oil is used?
The leak is slow and looks to be coming from the seal around the oil housing rather than internally which is what leads me to believe that is a leak.
Would email support directly but couldn't find a contact number on the site.
Chris
Turbo Roteo small fluid leak
