Hello
I am trying to find in the app a display option of watts using a moving average power of 3 to 5 seconds.
For progressive intervals where you need for instance to increase 15 watts every 5 minutes it is almost impossible to follow the training accurately because of the watts jumping up and down from one second to the next.
Do you have such option? If not please please please develop one, most of the work outs we do on the trainer will gain quality if the power display can be smoothed.
Francisco
Displaying moving average power data
franciscopalacios
Re: Displaying moving average power data
Please can you tell me which trainer do you have?
If it is Drivo, Kura or Direto you can find the power smoothing option in the advanced settings.
The maximum value is 10 (it means 10 pedal strokes, so it is higher than what you're asking - but it depends on your rpm)
franciscopalacios
Turbo muin
Turbo Muin is not an interactive trainer, so you shouldn't have an instable power value if your speed is costant.
Please contact our customer care adding some screenshot of the results of your training or an exported training.
