Video with the problem - https://www.youtube.com/watch?v=XNzcczg8ldM
Suito-T problems after software update
Hello! Last weekend I got my new Elite Suito-T trainer and before I started it, I updated it through the Elite upgrado app. When the update was done and the cassette was installed, I took it to my training room where I would connect the bike with trainer, but when I reconnected the trainer, it no longer worked. At first, middle light comes on for short time, the trainer makes a small sound and that's it. Additionally, I added a link to the video where I show the problem. I don't know what to do, so I'd like to know what can I do! I also checked the adapter voltage and it was 12V so i guess that can not be the problem!
Re: Suito-T problems after software update
Please contact the customer care. It seems something related to the electronic circuit board.
vladimiro.mourato
i have the same problem after i try to do the upgrdade to the last one.
did you resolve the problem?
tks
tks
If your trainer resistance seems to be stuck, first thing to check is the motor.
Run my e-training and select level mode. Pedal at constant speed and increase gradually the level.
If the resistance doesn't change, there may be a problem on the electronic board or on the motor.
In this case, contact our customer care:
Problem solved : new electronic card.
Thank you Elite support.
I hope problem solved for a long time...
frennarp78
Aaarrghhh…same problem for me…just bought a Elite Sterzo smart, and upgraded that via the Elite app, and after that the trainer,,,hahahah..(crazylaugh)…sittning here now with a brand new updated Sterzo and a not working trainer….
timo.schindler
The support can help you. Quick response and fixing was easy!
fernando.cruceros
Having the same problem, I contacted customer support, but I live in Mexico and the time difference between Mexico and Italy is not helping.
I will keep you posted if we can find a solution for this problem.
Links to the videos:
https://photos.app.goo.gl/JQngxJQS6RGx3HwJ7
https://photos.app.goo.gl/H5LhizRjYUo8DvXd8
f.siebeling
Suito werkt niet na Update.
Mijn suito-t geef tijdens de training wel de tijd en mijn hartslagmeter maar geen snelheid en afgelegde afstand. het fietsje beweegt niet
