FTP ramp test inconsistent resistance buildup
sophism06
Postby sophism06 » Fri Dec 10, 2021 11:32 am
Just did my first FTP ramp test in Zwift on my Elite Suito, but there is something I do not understand. The resistance buildup was so minimal that I maxed out my gears and was spinning at 120rpm @360Watts. The next step to 380Watts the resistance increased with a big leap at once and then I was done for….
I have calibrated the trainer before hand.
Any thoughts on what this might be or am I just a lot less fit than I thought :lol: ?
Re: FTP ramp test inconsistent resistance buildup
Postby Elite Admin S » Tue Dec 14, 2021 11:31 am
did you try contacting Zwift support?
What do they say?
sophism06
Postby sophism06 » Tue Dec 14, 2021 11:42 am
Ended up following these steps and then it did work :).
Warm up on the trainer for 10mins. Do a few hard efforts.
Disconnect EVERYTHING. ...
Plug the Suito in.
Open the Elite MyEtraining App.
Connect / Advanced / Calibration.
If that completes then close the MyEtraining app.
Open Zwift / pair everything / ride on.
Return to “Smart Trainers”
