Elite qubo mag smart b+ didnt fit
Sobamee
Postby Sobamee » Thu Nov 18, 2021 5:50 pm
Hi, im using a cheap bike with solid bolt axle.
It doesnt fit. Qubo handle is too short.
Is there a way to make this work?
Re: Elite qubo mag smart b+ didnt fit
Postby Elite Admin S » Fri Nov 19, 2021 9:51 am
Can you tell me the diameter of the axle?
Sobamee
Postby Sobamee » Fri Nov 19, 2021 3:58 pm
Hi, thank you for your reply. I manage to solved the problem by adding another m10 screw on one side of the axle. So now I can hook the bike however I now have a new problem.
On the remote I turn the settings to 1 and now I cant turn it back to 8. The remote wont move from 1 it stuck there. Is the unit broken?
Postby Elite Admin S » Mon Nov 22, 2021 1:45 pm
It may be...
Contact the support:
Return to “Smart Trainers”
