Hi, I have just used my Direto XR for the first time today. I paired it to my iPad and Garmin. In the myETraining app I have the wheel at 2096 and in my Garmin it is at 173. I have just done a pyramid, increasing power every two minutes by 20 watts, however the speed stayed constant at 12mph all through the program. Lowest 100w and highest 240w. Is this correct?
The speed was the same in my iPad and Garmin.
Thanks in advance.
Constant speed in myETraining app
Re: Constant speed in myETraining app
It's correct if your speed is that
If you accelerate and decelerate, speed should change.
