Non-Drive Side Large Nut
Matrix
Postby Matrix » Sun Oct 24, 2021 10:51 am
The large conical nut on the non-drive side of the spindle has come loose after 2 years of use. I’m just not sure how hard to tighten it back up - hand tight or should I get a large spanner on it to tighten it properly?
red.hell
Re: Non-Drive Side Large Nut
Postby red.hell » Sun Oct 24, 2021 3:00 pm
I think it's better with a spanner, and you have to block the cassette to tighten it, I think I have already done it once
Postby Elite Admin S » Tue Oct 26, 2021 11:59 am
It's better to do it by hand (is more confortable).
You have to use a wrench to tighten it while you hold the pulley:
Return to “Suito”
