Direto XR flywheel screws
lennart.nap
Postby lennart.nap » Sat Oct 16, 2021 10:48 pm
How are the screws supposed to look like?
My new Direto XR has 4 out of 5 screws that look like wood screws with a sunken head (that is ofc not sunken in the flywheel)
The 5th screw is different. Has some spacers and touches the plastic casing when I use the trainer which makes it sound like a motorbike.
4 of these wood screws:
1 of these that touches the casing:
Do yours look the same?
Re: Direto XR flywheel screws
Postby Elite Admin S » Mon Oct 18, 2021 10:20 am
It's not possible to understand from that photos.
I suggest you to contact our customer care adding some more photo (especially without the plastic cover) to understand better your question
To remove the plastic cover, follow the instructions in this link (only the part removing the carter):
https://elitesrl.zendesk.com/hc/en-us/a ... ack-Pulley
