Can I use Suito without fully unfolded legs?
lukas.droppan
Postby lukas.droppan » Wed Sep 29, 2021 9:10 am
Hello, I am planning to buy Elite Suito trainer, but since I have very limited space in my flat (trainer will be placed next to wall), I am not sure if it's good idea to use it the way I am planning to do.
Is it safe / possible to use Suito without fully unfolded legs? Without fully unfolded legs I mean, opened to maybe to 70% what is possible.
I am not planning to do any sprints or ride out of saddle to destabilise the trainer.
I really like all the features that Suito has but this is something that really bothers me.
I couldn't find any answers to my question so I think there is no better place where I can ask this.
Right now I have Elite Qubo Fluid which is about 60cm wide, Suito has more than 15cm + in width.
I am fully aware that it can destabilise the trainer, I am more bothered it it can damage it or not.
Thanks for help.
Re: Can I use Suito without fully unfolded legs?
Postby Elite Admin S » Wed Sep 29, 2021 10:20 am
We highly recommend to open completely the legs.
If you fall with the bike on a side the risk is to break the trainer.
lukas.droppan
Postby lukas.droppan » Wed Sep 29, 2021 10:59 am
Thank you, so I have to find different solution / trainer, maybe from a different manufacturer.
Return to “Suito”
