My Windows Update throws an error. It says:
"There were some problems installing updates, but we'll try again later. If you keep seeing this and want to search the web or contact support for information, this may help - (0x80070057)."
Retrying doesn't help and searching the web doesn't help me find a solution applinked
In the feedback app there are at least 15 reports of the same error, so this is a (rare) 9926 problem.
Anyone had the same issue and found a solution?
Windows Update 0x80070057 error
