Direto bearings
Declan
Direto bearings
Postby Declan » Wed Sep 15, 2021 8:31 am
Hi there.
Elite customer support have been brilliant and are sending me a replacement board to get my resistance working again, but I have a couple of questions.
1. I think my Direto needs new bearings for the axle that runs the red fan and small flywheel. See image below.
Can someone tell me what code the bearings are so I can get the correct size.
2. The silver flywheel on the shaft in the picture below, is it just the nut that holds it onto the shaft?
Re: Direto bearings
Postby Elite Admin S » Wed Sep 15, 2021 10:09 am
The bearings cannot be replaced without proper equipment.
May I ask you why do you want to replace the bearings? Did you notice any strange noise coming from the trainer?
I'm not sure about the part you're holding in your hand, is it a simple washer? Or is it opened (seeger/circlip)?
Declan
Re: Direto bearings
Postby Declan » Wed Sep 15, 2021 10:27 pm
OK. No problem. The picture is a screen shot from your "Pulley Glueing Instructions"
I think my trainer has already had the pulley glued before I bought it but it is making a loud rumbling sound like worn bearings.
Re: Direto bearings
Postby Elite Admin S » Thu Sep 16, 2021 8:11 am
Hi Declan
I see that you're already in contact with one of our technician to solve the problem.
