Suits Elite not recognizing serial number for redeeming coupon
andriesb
Postby andriesb » Thu Sep 02, 2021 8:01 am
I can not enter the serial code on bottom of trainer. It says it is not recognized. Error E1005. I have experience similar problems in the past and I think it might be caused by someone opening the box,accessing the code and using it. Is this the case?
See attached image
thanks
Andries
Screen Shot 2021-09-01 at 10.52.33 PM.png (26.85 KiB) Viewed 74659 times
Re: Suits Elite not recognizing serial number for redeeming coupon
Postby Elite Admin S » Thu Sep 02, 2021 11:34 am
Please follow these instructions to run the diagnostics and open a ticket:
https://elitesrl.zendesk.com/hc/en-us/a ... iagnostics
In the text of the email specify:
- trainer model
- trainer serial number
- error received
We will check the data and unlock the subscription
antoni70
Postby antoni70 » Sat Mar 11, 2023 8:31 pm
Hello i try 5 or 6 times the SN bueno alltimes sayd is a wrong number, any hello, please, thanks.
Postby Elite Admin S » Mon Mar 13, 2023 10:52 am
Contact the support, the guys there will check what's wrong with the serial number:
timothyferriss
Postby timothyferriss » Tue Oct 10, 2023 6:14 am
Error E1005 typically indicates that the serial code entered is not recognized by the system. While it's possible that someone may have accessed the code and used it in the past, there could be other reasons for this error as well.
recch1985
Postby recch1985 » Wed Oct 18, 2023 4:21 am
Hello, good evening, I need help with my coupon, it is a direct xr-t roller, code xri213863, the error I get is e1005, thank you. recch1985@gmail.com
Postby Elite Admin S » Wed Oct 18, 2023 2:30 pm
You have to contact the support:
paul.canham124
Postby paul.canham124 » Tue Nov 19, 2024 7:58 pm
Bought a new trainer serial number invalid on coupon redeem. must entered it 6 times. Error E1014
Users browsing this forum: Bing [Bot] and 38 guests
