New Direto XR calibration value is off!
flo.stuempfl
Postby flo.stuempfl » Fri Aug 20, 2021 5:18 pm
Hey guys,
last week I bought a new direto XR. After finished my first ride I did a calibration in the elite mytrainer app, the value i got was 6534, but on the bottom of the trainer it reads 6536. The ride the day after i felt my power numbers were a bit low. Do i need to tighten any bolts or is the value still exceptable? Greets
simon
Re: New Direto XR calibration value is off!
Postby simon » Sat Aug 21, 2021 9:02 pm
The power numbers reported take into account the offset value acquired during calibration. If the belt isn't slipping, you should be fine. I've ridden for a few years (with the original Direto) with my calibration number -4 from the number on the bottom of the trainer. Power values are within 2 - 5 watts of my Garmin Vector 3 dual sided power meter (e.g. < 1% difference).
flo.stuempfl
Postby flo.stuempfl » Sun Aug 22, 2021 10:11 am
Hey simon,
thanks for your nice answer. Then I will leave things as they are. Greets Flo
