RIZER
RIZER
Postby Elite Admin S » Fri Jul 30, 2021 12:19 pm
Some juicy news for you today! Read on!
Real climbing feel. Integrated steering.
FIND OUT ALL ABOUT THE RIZER ON https://www.elite-it.com/en/products/ho ... ries/rizer
Raise your indoor cycling game with the Rizer, Elite’s gradient simulator with steering.
The latest addition to the Elite ecosystem will raise and lower your bike to give you real-time inclines and declines as you blast those climbs with your trainer. The Rizer will get you out of your saddle with immersive grade changes as if you really were riding outdoors by simply connecting with nearby home trainers.
Featuring sturdy hardware design, the Rizer will provide with true-to-ride inclines up to 20% and declines as low as -10%.
For more focused and realistic rides, our gradient simulator features the innovative steering system designed to improve the handlebars’ feel when you’re going uphill, and help you work every muscle as you would do if you were actually riding outdoors.
What can the Rizer do
The Rizer grade simulator can make you feel all the power of your favorite summits and help you attack the effort for the next climb when you’re riding your bike indoors.
But it’s more than that.
The Rizer features hardware technology with steering functionality so you can easily move your handlebars left and right when you’re smashing those climbs.
This will improve handlebar feel and comfort, and help you use the same muscle groups on legs and shoulders that you’d be using if you were really riding your bike outdoors, uphill.
Our testers were also impressed with the chance they had to test new bike positions and prepare properly for their next climbs on their bikes.
Elite Compatible trainers:
Direto XR, Direto XR-T, Suito, Suito-T, Tuo.
Included adapters:
QR, 12x100, 15x100, 15x110.
Control App “Rizer"
available on the App Store and Google Play.
farare
Re: RIZER
Postby farare » Thu Mar 13, 2025 4:50 am
Feel every climb and descent! The Rizer raises and lowers your bike, simulating real road conditions for a more dynamic and engaging indoor ride.
Geometry Dash
pierre.lepeer
Re: RIZER
Postby pierre.lepeer » Wed Jan 14, 2026 2:28 pm
I have had a strange issue since the last firmware update on my Elite Rizer:
The Rizer goes up and down in ERG mode, which is new, but in a way that doesn't make much sense (sometimes, when changing blocks, it goes down to the lowest point, then back up to the highest point, then settles somewhere in between).
In simulation mode, sometimes it goes down when I'm going up, or vice versa, or moves position on flat ground. It's as if it were more sensitive to slope variations than to absolute slope values.
For example, if the climb goes from 8% to 6%, the Rizer goes down, then returns to the correct position after a few seconds, and vice versa (if I go from -8% to -6%, it goes up).
Setup:
    Elite Direto XR-T - Firmware 89
    Elite Rizer - Firmware 33 - With all settings checked (horizontality, wheelbase, trainer difficulty, Zwift descent compensation, my weight and that of the bike)
    Garmin Cadence Sensor connected to Direto
    Companion App updated on iPhone 13 Pro iOS 26.2
    Zwift App updated on Apple TV 4K TVOS 26.2 on the same WiFi as the Companion App
    Polar H10 (Dual Bluetooth - ANT+)
    Wahoo HeadWind connected via ANT+ to Polar H10
Return to “Hot News!”
