Crono Hydromag Fluid Refill
crichterstein
Postby crichterstein » Mon May 31, 2021 4:07 pm
Hi, I received a used Crono trainer. One big screw (picture) was removed and "fluid" leaked out. I dont want to use the trainer without refilling it...What kind of oil or liquid should I put there? Any ideas?
Christian
20210531_095455 (002).jpg (118.46 KiB) Viewed 24080 times
Re: Crono Hydromag Fluid Refill
Postby Elite Admin S » Tue Jun 01, 2021 8:51 am
We can send you the oil to refill.
Please contact the customer care through our support page:
https://support.elite-it.com/
To open a ticket, simply select the correct trainer and then click on the open a ticket link
Return to “Other Trainers”
