Am I correct in saying there is a belt inside the muin which you can adjust the tension which will in turn affect the resistance of the trainer?
Could anyone link me to the manual of the trainer so I could have a look please
Muin Trainer
Re: Muin Trainer
This is not correct.
The resistance of Turbo Muin depends mainly on the oil inside.
May I ask you why you want to change the trainer resistance?
