Hi, I've just bought a Direto.
- I've assembled it. Mounted the cassette, All the mechanics are good
- I've powered it on. All LEDs are lit. Power LED on solid. Bluetooth LED flashing ~ 1hz, ANT+ LED flashing ~1HZ
I've tried using the myEtraining app on my iPhone 12 to connect and configure the Direto.
- I have bluetooth on and working on my phone.
- I start the myEtraiing app, select configure trainer and select Direto as the trainer type (using the QR code)
- it then says start pedalling. After 30 minutes of pedalling nothing happens.
What should happen? Is there some sort of user guide that should tell me that to do?
No connection
Re: No connection
Check this troubleshooting:
https://elitesrl.zendesk.com/hc/en-us/a ... -problems-
If still you're having problems, contact our customer care (select the trainer, then select on the link to open a ticket):
https://support.elite-it.com/
