Hi all,
I have recently purchased a diretto XRT smart trainer and I'm still trying to get used to its features. Is there a way to set a gradient of lets say 3% and keep it for the entirety of the session? instead of using ERG or Level mode.
Set Gradient
Re: Set Gradient
Yes, it's possible if you use our my e-training application.
You have to select workout - program mode and then create a slope/time or slope/distance program
b_clive@hotmail.com
Re: Set Gradient
Thanks, I think that will do just right
