Direto X calibration question
Jinesh
Postby Jinesh » Tue May 04, 2021 10:03 am
I have a Direto X base trainer. when doing a calibration with E trainer, based on the sticker under the trainer, i should have an offset of 6457 but i'm at 6459. Is that a problem or it's ok for https://snaptube.cam/?
Thanks for your help
Re: Direto X calibration question
Postby Elite Admin S » Tue May 04, 2021 10:29 am
Are you sure to have done a 10 minutes training before running the calibration? This may justify a higher offset value.
Also, there may have been an error in the value on the sticker. Can you tell me your trainer serial number?
Anyway, the difference is very low so it's not a problem.
