Hi!
I've been using the Elite Direto for a couple of years and have never experienced any issues but the other day the Erg mode stopped working all of a sudden.
I've tried in both Trainerroad and Zwift and it seems to be the same problem in both. The trainer just doesn't change the resistens automatically anymore. If i put on a light gear and pedal slowly my power will be much below target instead of increasing the resistens so that my power is on target.
I'm on the latest firmware. TOP 10 VOICE GENERATORS REVIEW
What can I do?
Thanks!
ERG mode not worknig
Re: ERG mode not worknig
Run my e-training and select level mode (it's available even without subscription).
Pedal at constant speed and increase gradually the level.
Do you feel the resistance change?
If not, the problem may be on the electronic board.
In this case, you have to contact our customer care that will ask you some specific test and if necessary send you a new board:
https://support.elite-it.com/
Remember to specify the model of the trainer and its serial number when you write the email
https://elitesrl.zendesk.com/hc/en-us/a ... ial-number
