Vibration during increased resistance
graham.hobson
Postby graham.hobson » Wed Apr 21, 2021 5:00 pm
I have started to experience a vibration from my Suito that I can feel right through the bike, pedals and handlebars. When the resistance is low the vibration is not there, it occurs when the power is approx. 120w and above.
I have another bike that I have tried on the trainer and the same happens so there is nothing loose or vibrating on the bike itself. Before this started happening I had noticed that when resistance is increased there is a knocking noise from the trainer. It is not a loud knock but it is definitely there and it wasn't there from new.
Please offer some advice as to what this could be. I've had the trainer for less than 12 months.
Re: Vibration during increased resistance
Postby Elite Admin S » Thu Apr 22, 2021 9:10 am
Contact our customer care:
https://support.elite-it.com
Specify the trainer model and the serial number.
The guys there will help you to solve the problem
graham.hobson
Postby graham.hobson » Wed Apr 28, 2021 6:35 pm
That link just takes me back to the page with the frequent questions, the knowledgebase and the link back to this forum. Where is the link to actual Customer Care as you suggest?
The actual 'Support' link on that page links back to itself. What's going on? Where is actual support?
hernandez_christ
Postby hernandez_christ » Wed Apr 28, 2021 9:13 pm
3 clicks away.
On the support page, click on trainer, click on your trainer, scroll down and click on "here" to open a ticket.
Postby Elite Admin S » Thu Apr 29, 2021 8:50 am
Exactly hernandez_christ! 8-)
graham.hobson
Postby graham.hobson » Thu May 06, 2021 1:09 pm
OK found it!
Not exactly obvious is it?
rickhabets
Postby rickhabets » Mon May 23, 2022 9:52 pm
graham.hobson wrote:OK found it!
Did you manage to fix this?
I'm experiencing the same problem. Once I start going over 150w, I can feel the trainer start to vibrate.
Postby Elite Admin S » Tue May 24, 2022 8:19 am
Hi rickhabets
I suggest you to contact directly our support.
Add a video in which it's possible to hear the noise and specify the serial number of the trainer
Return to “Suito”
