Can anyone help with where I can get a replacement nut for the Directo trainer. The original was quite a soft metal and has been damaged changing over the cassette.
I have looked online but can’t find anywhere that has the 142x12 one
Replacement 142x12 attaining nut
hernandez_christ
Re: Replacement 142x12 attaining nut
You should contact the support directly. They will surely have spare parts for you.
If you mean the rotating nut of the Direto XR, you can find it here:
https://www.shopelite-it.com/en/sensors ... -direto-xr
If you have a Direto or a Direto X instead contact us from here:
https://support.elite-it.com/
