Direto power meter
Blackett
Direto power meter
Postby Blackett » Sun Mar 21, 2021 9:40 am
i have a Direto x its power meter has started to act up one minute it was fine then i lost everything watts and hr no numbers , it lasted for roughly 20 seconds then watts and hr came back but froze for another 10 seconds, Any one have an idea whats going on please thanks in advance
Re: Direto power meter
Postby Elite Admin S » Tue Mar 30, 2021 10:58 am
It seems a disconnection.
It may be due to some interference.
Try powering off any wireless device in the area (other smartphones, tablets, Wahoo/Polar/Garmin devices, speakers... all of them).
Try also powering off your wifi (it may cause interference, and in that case it is necessary to switch to a different channel)
If you're using a pc and an ant+ dongle or a bluetooth dongle, try also using a usb extension cable to put the dongle closer to the trainer.
If you've tried all of the above solutions and still you have disconnections very often, contact the customer care at info@elite-it.com
