Direto Calibration help needed
gleaney
Postby gleaney » Tue Mar 16, 2021 8:22 am
Good morning. I wonder if anyone can help. I’m trying to calibrate my Direto but every time I try I get Failed Calibration message.
I’m doing the 10 min warm up and the doing the calibration through the app. I’ve tried Bluetooth and ANT+ independently through different platforms which are two iPads an iPhone and a Mac book air. The software is fully updated as is the firmware on the Direto which was done through the Upgrado app.
gleaney
Re: Direto Calibration help needed
Postby gleaney » Wed Mar 17, 2021 2:15 pm
ok. SITREP !
So today having done a bit of research I tried this.
Do the 10 min warm up with no power to the Direto at all. After that plug power in and open up the MyTraining app. I used a mac book air on bluetooth.
I ran the calibration test but instead of stopping at 33k/h I went flat out and got to about 65k/h. And an offset came back which was within 1 unit of the offset on the bottom of the machine. I hope this helps others as it appears to be a common problem.
Postby Elite Admin S » Wed Mar 17, 2021 2:27 pm
If you use my e-training, here's the calibration steps:
- first of all, do a 10 minute training to warm up your trainer (ideally, 10 minutes at around 20-25km/h and 100-150W)
- then run the calibration
- the app asks you to start pedaling
- the app asks you to reach a target speed (remember to overcome the value, not only reach!)
- the app asks you to stop (stop pedaling, don't move the pedals until the procedure has been completed)
ATTENTION: this do NOT work for Nero trainers! There calibration must be done in a different way
If you use Zwift, be careful.
Some times ago there was a bug, the software seemed to ask to reach a wrong speed (over 60km/h).
It's a bug, they will correct it.
gleaney
Postby gleaney » Wed Mar 17, 2021 2:34 pm
Thank you Elite for your response.
Users browsing this forum: No registered users and 50 guests
