I just bougth an Elite suito T.
I connected it to my computer through ant+. Everything connected fine, including FC from my Garmin watch.
Problems start when i turned on bluetooth on my cell phone. Then i loose controlable fonction from the Suito.
If i turn my cell BT off, controlable restart to work properly.
Here my question. Why is suito BT antenna contuniing searching for other device once fully connected? Can we set suito to force its BT antenna to stop searching?
If someone has an answer, please let me know.
NicoolasP
Bluetooth interference with ant+
ymarti.ymarti
Re: Bluetooth interference with ant+
Same experience. Only a device with a elite app works properly.
Also with garmin connected some trouble.
Only a question: to connect FC from your Garmin watch....do you have procedure? Broadcasting?
Thanks a lot
marti
Thanks a lot
marti
GOD SAVE THE RIDER
hernandez_christ
As far as I know there is no way to control the home trainer else than through an app, so you won't be able to deactivate the Bluetooth antenna.
Maybe you can go in your phone settings and make it "forget" about the home trainer to prevent it to get connected when your mobile is nearby.
Christophe
Christophe
