Direto calibration
fuego.bluedane
Re: Direto calibration
Postby fuego.bluedane » Fri Sep 20, 2019 8:32 pm
elite wrote:Isn't Ok. Max difference is 5 points. You should do calibration https://www.youtube.com/watch?v=LLrK-5J ... dex=3&t=0s
The video of calibration is unavailable?
If my offset is lower more than 5 points than offset from sticker what should i do?
marconazzi
Postby marconazzi » Mon Nov 04, 2019 1:54 pm
Even on Direto X you have to follow the same calibrations? and if you use it on erg mode but with Quarq PM, it is still needed?
daniele.testa1979
Postby daniele.testa1979 » Fri Nov 08, 2019 11:25 am
Hi, using Garmin 820, I have some questions:
1) How can I calibrate the Elite direto?
2) How can I define the circumference of the wheel?
3) Erg mode is an automatic function? If I set an interval 240 - 260 watt for 5 min., the direto keep this power?
flimps
Postby flimps » Wed Dec 04, 2019 11:09 pm
Mine shows a circumference of 2070 and is showing. 10-20 watts above what vercto 3, stages and 4iii show.
Any suggestion to have drivo 2 showing the correct power?
hector157
Postby hector157 » Mon Aug 03, 2020 5:25 am
Trying figure my calibration offset value was 6379 is this correct
heiko
Postby heiko » Sat Aug 08, 2020 12:09 pm
according to Elite support (19.07.2020) there is no strict limit:
"A difference of +/- 7/8 points is completely normal unless you don't notice something wrong with your trainer.
I suggest you to keep using your trainer without any worries and to contact us if you notice some problems with your Direto."
nicholas.anthonythomas
Postby nicholas.anthonythomas » Thu Aug 13, 2020 1:41 pm
My Direto X has gone crazy in the last 2 weeks. Worked perfectly for 4 months.
First the spin down calibration was asking me to speed up to 54.6kph instead of the usual 20kph, would then spin down all the way to 0 and nothing would happen. It would always read 10-15 watts higher than 4iii and vector 3's
This afternoon i went through the same issues on Trainerroad but it somehow had a successful calibration in less than 1 second of spindown but was reading 50watts higher than my vector 3 pedals for a steady state recovery ride.
Anyone have any ideas on whats going on?
david931
Postby david931 » Wed Oct 13, 2021 1:36 am
I have had my Direto for about 18 months. In all that time I have been unable to calibrate it. I have tried multiple times with the Android myETraining app but the calibration always fails in the same way :
"please start pedalling" - I do
"pedal faster to hit the target speed of 33 kmh" - I do
"please stop pedalling and wait for a response" - I do
"target speed was not reached, try again"
The app consistently does this and I have tried it on 3 different devices.
My 4iiii power meter reports ~ 30 watts less power than the Direto. I can and do calibrate my 4iiii. So the Direto looks to be vastly over reporting power. So I need to get it calibrated. Or else it goes on ebay.
Elite admins - please help me.
Postby Elite Admin S » Wed Oct 13, 2021 8:05 am
Hi David
If you do a normal training, speed seems correct?
Can you tell me which circumference value did you set in the configuration?
david931
Postby david931 » Wed Oct 13, 2021 12:04 pm
Yes - speeds seem normal during training, when on Zwift maybe slightly higher than I would expect in the real world.
Circumference is the default suggested by the app - 2070 I believe.
I looked at the youtube video for calibration of Direto - my Direto does not have any similar place to adjust belt tension - but the app QR scanner tells me it is a Direto (not some other variant).
And BTW - when asked by the app to speed up to 33 kmh, I can see a realtime output on the app showing me go over 33 kmh after which the dialog disappears and I am then told to stop pedalling. So the app thinks I got over 33 kmh by the looks of it.
David.
