Direto II Disable ERG Mode
Vorko76
Postby Vorko76 » Sat Dec 19, 2020 11:53 pm
I have noticed the same behaviour on Zwift and Rouvy and I'm curious to understand it :
- when the incline reaches 8%, the Direto starts to make some noise like if something is trying to slow the flywheel. This might not be an issue but still is surprising
- in parallel I believe the ERG mode starts (I believe): the resistance of the trainer does not increase but the speed I go to in Rouvy or Zwift goes down.
=> Is this normal? I'm not especially powerful and produce around 2.1 W/kg at 8% (and more) for 85 kg. But my understanding is that this should happen at around 14%, not 8%
=> Is there a way to disable this or change this behaviour?
