Misuro blu not transmitting
svesin
Postby svesin » Tue Dec 15, 2020 6:29 pm
Hi, I try to set up my qubo power smart with the misuro blu.
I could configure the qubo to connect to the misuro and the heart sensor but when I try an FTP test I get an error that no data could be transmitted and to check my Blutooth settings. I placed the misuro exactly as explained in the manual (see attachment). What else can it be ? Thanks
dario.boero
Re: Misuro blu not transmitting
Postby dario.boero » Thu Sep 08, 2022 7:56 pm
I know it's a old post,but I've the same problem,did you find a solution?
Postby Elite Admin S » Wed Sep 14, 2022 12:06 pm
Do you also have the misuro blu (black version)?
Check position and battery charge level.
If the problem persists, contact our customer care:
Return to “Misuro”
