I have a elite suito that I got in May 2020 & I have recently noticed a humming sound while I power on or stop my pedaling. Posted the vdo in my youtube channel
https://youtu.be/OzDUW5OAEkA
Humming sounds in Elite Suito
camillo.vezzoli
Re: Humming sounds in Elite Suito
Did you find a solution, I'm experiencing the same.
Hi. Did you resolve this? I have the same. Ta Calum
When you hear strange noises or sounds from the trainer, it is always necessary to contact the support:
This because we have to hear that noise to understand the possible cause (you may think that all the noises are similar, but that's not true).
There are many causes that can create this issue and every one needs a different procedure to be solved (adding grease somewhere, replace a part, tighten a screw...)
