Elte Rampa--Centering Tire
munoabr8@gmail.com
Postby munoabr8@gmail.com » Tue Oct 10, 2017 2:52 pm
I have had my Rampa trainer for a few months and I have noticed that the rear tire has moved away from the center of the roller. I have attempted to adjust the unit support bolts as described in the instruction manual however the tire is still not centered. Any suggestions?
Abe
Re: Elte Rampa--Centering Tire
Postby Elite Admin S » Wed Oct 11, 2017 8:57 am
Depending on the bike, the wheel may be a little on the left or a little on the right (not centered).
It's normal, if the wheel touches only the elastogel roller and not the side plastic covers, there's not problem.
If you have still some doubt, send me a photo and I'll let you know if all is mounted properly
Return to “Rampa”
