Exporting to Today'sPlan?
davidrich
Postby davidrich » Tue Oct 10, 2017 11:07 am
Hi, I just bought a Volano Smart B+ and have managed to connect the myETraining App and the trainer etc and can automatically exprt data to Strava, but I now need to transfer workout data from the myEtraining app to 'Today's Plan' so that my coach can view the files. How do I do this? Thanks.
Re: Exporting to Today'sPlan?
Postby Elite Admin S » Tue Oct 10, 2017 11:40 am
I'm not sure to have understood your request. But I think you have to contact Strava.
ftrout
Postby ftrout » Fri Nov 10, 2017 7:31 pm
Same thing here !
Today's Plan is a training/coaching platform similar(and in my opinion beter) to Training Peaks, it's used by team Sky and Trek Segralfredo.
https://www.todaysplan.com.au/
Zwift, TrainerRoad, Garmin, Pref Pro Studio, Computrainer are all curently intagrated with Today's Plan.
https://www.todaysplan.com.au/2016/12/todays-plan-ecosystem/
If you have done integration to Training Peaks, integration to Today's Plan should be easy to do.
Here is the API reference:
https://www.todaysplan.com.au/api/
Please make it hapen !
henry.oosterling
Postby henry.oosterling » Sun Apr 29, 2018 1:15 pm
davidrich wrote:Hi, I just bought a Volano Smart B+ and have managed to connect the myETraining App and the trainer etc and can automatically exprt data to Strava, but I now need to transfer workout data from the myEtraining app to 'Today's Plan' so that my coach can view the files. How do I do this? Thanks.
Hi David, my cousin just received the Misuro B+ dongle but noo way we manage to get the Volano paired with the dongle. It just doesn't recognize each other plus it goes in standby mode so no option to install it in the trainer. Can I ask you how you paired the trainer with the dongle in combination with MyEtrainer. Until now it all doesn't make sense at all.
Postby Elite Admin S » Wed May 02, 2018 9:12 am
Hi Henry
Can you tell me the model of your cousin's smartphone?
Are you sure that the misuro is properly set (14 blinkings) and it is in the correct position? Remember that orientation is important.
Also, which error does he get in the app when he tries to connect?
