Hello!
I am using a real power wired and the problem ist, that a lot of videos are not synchronous. Especially "Nove Colli" for example: The Video shows downhill, BUT the shown resistance (for example +5%) and the simulated used resistance is uphill (like the shown resistance)! The difference is about 200 Meters!
Is there any possibility to synchronize the Videos and the resistance???
Thank you and regards vom Munich,
Stephan
nonsynchronous
Re: nonsynchronous
Try disabling virtual speed, this should solve the issue
I think that you have an old version of the software (I suggest you to update it - you can also contact our customer care at real@elite-it.com and ask the latest beta version, that also fix a problem with geo-located courses)
