Elite Novo Smart underestimating watts
stuartlaidlaw
Postby stuartlaidlaw » Tue Oct 20, 2020 11:46 pm
I’ve got a Novo Smart which I’ve had for about 18 months and been totally happy with it using it on Zwift, all of a sudden on Sunday it started playing up.
When I pedal on the flat at 0% gradient it says I’m only putting out about 100 watts and I can only get up to about 15kmh, I’ve been using it long enough to know that that intensity of effort is around 250-300 watts. It feels like the resistance has jammed somehow.
Does anybody have experience of this, or even better a fix!
It’s very poor for a device to fail within 2 years.
Matt.thomas93
Re: Elite Novo Smart underestimating watts
Postby Matt.thomas93 » Thu Jan 07, 2021 8:41 am
I have the same issue! However I tried to do a calibration prior to my Zwift ride. Logged into Zwift.. would connect fine like normal then on the ride I struggled to get past 5-70watts? Anyone have a solution for this?
wie_san_lau
Postby wie_san_lau » Sun Jan 10, 2021 1:15 pm
I'm also getting low watts, and hard to pedal. Resistance doesn't change when testing on the E-Training app.
I've taken off the cover and the panels of the side, and still cannot see anything moving when i plug in on first start up.
https://elitesrl.zendesk.com/hc/en-us/articles/360014596239-Resistance-Check-On-Interactive-Trainers
Users browsing this forum: No registered users and 121 guests
